VLAN Manager is taking all CPU
Jun 9th, 2009
Any idea what this process is? Somehow the CPU util of the switch is now about 50%.
What is causing this?
36 297064492 5020384 59172 22.29% 24.76% 24.79% 0 VLAN Manager
Alvaro Garcia Tue, 06/09/2009 - 12:02
VLAN manager is the IOS platform shim to the VTP protocol. VLAN manager assumes the platform runs IOS and implements the port manager and IFS. VLAN manager implements the vlan database configuration mode and commands, vtp configuration commands and all the related show commands.
It would be good to check how many VLANs and STP instances your switch has. Get a show vlan, show run, show interfaces trunk.
However, my experience says that a CPU of 50% on a 4500 switch is still under a normal range.
Have you recently implement any configuration/topology change?
Al Garcia
ronshuster Wed, 06/10/2009 - 06:18
HI Garcia,
There was a change recently, we had a contractor come in and he did something and now our etherchannels to the Blades have a "B" next to them, here it is:
1 Po1(SU) - Gi5/1(P) Gi5/2(P)
10 Po10(SD) LACP
10 Po10B(SU) LACP Gi7/10(P) Gi7/11(P)
11 Po11(SU) LACP Gi7/12(P) Gi7/13(P)
12 Po12(SD) LACP
12 Po12B(SU) LACP Gi7/14(P) Gi7/15(P)
13 Po13(SD) LACP
13 Po13B(SU) LACP Gi7/16(P) Gi7/17(P)
14 Po14(SD) LACP
14 Po14B(SU) LACP Gi7/18(P) Gi7/19(P)
15 Po15(SD) LACP
15 Po15B(SU) LACP Gi7/20(P) Gi7/21(P)
16 Po16(SD) LACP
16 Po16B(SU) LACP Gi7/22(P) Gi7/23(P)
17 Po17(SD) LACP
17 Po17B(SU) LACP Gi7/24(P) Gi7/25(P)
18 Po18(SU) LACP Gi7/26(P) Gi7/27(P)
19 Po19(SD) LACP
19 Po19A(SU) LACP Gi7/28(P) Gi7/29(P)
100 Po100(SU) LACP Gi6/1(P) Gi6/2(P) Gi6/3(P) Gi6/4(D)
What is the B next to the po?
Ever since this B showed up, accessing the servers on the blade is very slow and latency is very high (like 200ms whereas in the past it was about 2ms).
On the blades themselves there are 4 vlans defined :
Port Mode Encapsulation Status Native vlan
Gi0/16 on 802.1q trunking 1
Po1 on 802.1q trunking 1
Po2 on 802.1q trunking 1
Port Vlans allowed on trunk
Gi0/16 1
Po1 1-4094
Po2 1-4094
Port Vlans allowed and active in management domain
Gi0/16 1
Po1 1,60-61,98,100,222
Po2 1,60-61,98,100,222
Port Vlans in spanning tree forwarding state and not pruned
Gi0/16 1
Po1 1,98,100
Po2 60-61,98,100,222
sh vlan:
VLAN Name Status Ports
1 default active Gi0/15
60 VLAN0060 active Gi0/6
61 VLAN0061 active Gi0/1, Gi0/2, Gi0/3, Gi0/4
Gi0/5, Gi0/7, Gi0/8, Gi0/9
Gi0/10, Gi0/11, Gi0/12, Gi0/14
98 VLAN0098 active
100 ComputerRoom-Servers active
222 VLAN0222 active Gi0/13
So why do we see the B on the po?
Why is the latency so high to the servers?
why is VLAN manager taking up all the CPU?
I tried to bounced one of the po and the B disappeared.
Any idea?
Alvaro Garcia Wed, 06/10/2009 - 12:38
About the "B" next to the Po; that is called alpha-numerical lacp portchannel, and it is usually seen when LACP protocol detects some inconsistency between channel member ports.. The inconsistency could be in either side of the channel. You should check logs of BOTH devices, usually this is due to channel misconfiguration between the ports you are bundling, or with their remote peers.
See the following document:
http://www.cisco.com/en/US/tech/tk389/tk213/technologies_configuration_example09186a0080094470.shtml#po1a
This mis configuration may be affecting the CPU as well.
I would suggest to contact the consultant and make him check the configuration.
Or send a show run, show etherchannel summ and show interfaces for both switches and I would give them a quick look.
ronshuster Wed, 06/10/2009 - 15:40
The blades are connected to two cores configured with etherchannel (made of 2 physical ports to each core):
Core 1:
12 Po12(SD) LACP
interface Port-channel12
description BC2-SW1
switchport
switchport mode trunk
switchport nonegotiate
no ip address
end
Core 2:
12 Po12(SD) LACP
description BC2-SW1
switchport
no ip address
end
Blade switch:
1 Po1(SU) LACP Gi0/17(Pd) Gi0/18(P)
2 Po2(SU) LACP Gi0/19(Pd) Gi0/20(P)
description Uplink to Core1: G6/7 - G7/7
interface Port-channel2
description To Core2: G06/7,G7/7
If you want more info, may I have your email address?
Alvaro Garcia Wed, 06/10/2009 - 15:48
Email is [email protected]
I'm seeing some discrepancy between the blade config and the cores' config. Is the command "switchport trunk encapsulation dot1q" available under the Int Port-channel on the blade switch?
Please send:
From Core1:
show run int po12
show run int gi7/14
show run int gi7/15
show int status
From Core2:
show run int po12
show run int gi7/14
show run int gi7/15
show int status
From blade switch:
show run int po1
show run int po2
show run int gi0/17
show run int gi0/18
show run int gi0/19
show run int gi0/20
show int status
ronshuster Wed, 06/10/2009 - 16:00
core1:
description BC2-SW1
switchport
no ip address
end
interface GigabitEthernet7/14
description BC2-SW1
switchport
no ip address
channel-group 12 mode active
end
Current configuration : 200 bytes
interface GigabitEthernet7/15
description BC2-SW1
switchport
no ip address
Core2:
description BC2-SW1
switchport
no ip address
end
description BC2-SW1
switchport
no ip address
end
description BC2-SW1
switchport
no ip address
end
BLADE
description Uplink to ESGBB1: G6/7 - G7/7
description To ESGBB2: G06/7,G7/7
interface GigabitEthernet0/17
channel-group 1 mode active
interface GigabitEthernet0/18
interface GigabitEthernet0/19
description Uplink to ESGBB2: G6/7 - G7/7
channel-group 2 mode active
interface GigabitEthernet0/20
To answer your question, the encapsulation option is not available on the switch, ie:
BC2-SW1(config-if)#switchport trunk ?
allowed Set allowed VLAN characteristics when interface is in trunking mode
native Set trunking native characteristics when interface is in trunking
mode
pruning Set pruning VLAN characteristics when interface is in trunking m
One thing worth noting, and that is when i bounced the port channels on the core, the "b" disappeared, but I only did this on one of the legs, I need to do it on both and see if hte CPU goes down.
From what you see so far, do you see any problems with the trunk configuration?
Alvaro Garcia Wed, 06/10/2009 - 16:21
The trunk and channel config looks fine. The mismatch could also be related to physical interface characteristics, like speed/duplex/status, etc.
If you do a show int for each of the physical ports do you noticed any discrepancy?
Bouncing the port channels would force the LACP auto negotiation and may fix the problem temporally. I used to be a LAN switching engineer on Cisco TAC and I worked many times with etherchannels; and I know that this channel negotiation configuration process maybe kind of tricky because you always have to configure each interface in the same way following the correct process otherwise the channel may present some problems.
What I normally do with this kind of alphanumerical channel issues is to send the physical ports to default settings and reconfigure the etherchannels from scratch, shutting down the physical interfaces firsts.
That is my recommendation.
ronshuster Wed, 06/10/2009 - 16:34
I will be bouncing all the port channels in a few hours and let you know if the problem is fixed... thanks for the advise.
