Incoming call blocking
Skyler Spence Tue, 06/09/2009 - 12:31
  • Bronze, 100 points or more
You could accomplish this using CLI.  If you are already using a translation profile on your incoming dial-peer, you can add a new rule to this profile or edit the existing rule.  Assuming that no translation profile is configured the steps would be something like:
voice translation-rule 11000
  rule 1 reject /9995551234/
voice translation-profile CALL_BLOCK
  translate calling 11000
dial-peer voice (incoming dial-peer(s) tag(s)) [pots | voip]
   call-block translation-profile incoming CALL_BLOCK
   call-block disconnect-cause incoming invalid-number
For more information about this feature, you can check out this document from cisco.com
http://www.cisco.com/en/US/docs/ios/12_2t/12_2t11/feature/guide/ftgwrepg.html#wp1038689
Notice that my translation rule and profile match the CCA out of band configuration guidelines, and my annoying
caller has a phone number of 9995551234.  I tested this out on my system, and while CCA does not seem to have any
problems with this code be aware that any changes to your dial plan may result in your dial-peer statements being
overwritten.
gandghauling Fri, 09/04/2009 - 14:04
I've created the necessary entries in the config but things are not working like I think they should.
When I call our system from an unblocked number the system rings extensions after the 1st ring like normal.  When testing from a blocked number I hear about 5 more rings before the system starts ringing the extensions.  Plus blocked numbers show up as unknown number on the caller id.
I was expecting a rejected calling number to be terminated as in disconnected or a hang up.
Can someone confirm my results.
Steven Smith Wed, 09/09/2009 - 10:05
  • Gold, 750 points or more
The configuration is correct.  You should post your config so that we can help debug this with you.  Remember to take passwords out of the config.
Richard Dumag Wed, 11/03/2010 - 14:35
Hi.  I saw this post.  Will this work for 2800 and 3800 series voice gateways?  We have the same issue and would like to block certain incoming calls.  We are still running Call Manager 4.1 however.  Thanks.
Okay, I have a follow-up here.  It seems that the limit is 15 numbers using the method outlined in this post.  Is there a way to go beyond the 15 number limit?  I don't want to block an entire area code or prefix, but we do get a lot of calls coming in from a certain area that mistake our phone number for an automated check in.
Thanks;
Richard
NYCiscoTech_2 Thu, 11/11/2010 - 15:10
Does anyone have an example using the default CCA built configuration on the UC5XX?
I have configured this on an FXO port, however I'm also experiencing the same issue.   Numbers part of the reject group receive ring back for 5 rings before eventually ringing the extension.
Thanks much.
mcasimirc63 Wed, 01/05/2011 - 16:43
  • Silver, 250 points or more
You can block calls if they use a dial-peer for incoming calls (i.e...SIP Trunks or PRI).  FXO ports use a connection PLAR command which forwards the number without the use of a dial-peer.
