Laurent Aubert Wed, 06/10/2009 - 05:47
Multicast allows you to send one stream than can be received by many Host or receivers. It's far more efficient than sending x times the same flow in unicast to each receiver.
The following links will help you to start with multicast:
http://www.cisco.com/en/US/products/ps6552/prod_presentation_list.html
http://www.cisco.com/en/US/docs/ios/solutions_docs/ip_multicast/White_papers/mcst_ovr.html
If you have a single LAN where your source and receivers are connected, you have nothing to do as L2 switches handle multicast packets as broadcast packets.
Laurent.
remco.gussen Tue, 06/23/2009 - 05:47
Hi Laurent
What do you have to configure if you have a few VLAN's connected to and routed by a 3750 core switch ?
Do i need to have the IP Services image ?
