DDNS w freedns.afraid.org
i guess that was a little ambiguous - it doesn't work. I've been through the iad_ddns doc backwards and forwards.
ip ddns update method not4u
add http://freedns.afraid.org/dynamic/update.php?U2lnOWswTVRTTUlBQUhTbmVvRTozNjI5NjQ1
interval maximum 0 0 5 0
interval minimum 0 0 5 0
001132: .Jun 11 16:07:26: DYNDNSUPD: Adding DNS mapping for not4u.ignorelist.com <=>
001133: .Jun 11 16:07:26: HTTPDNS: Update add called for not4u.ignorelist.com <=>
001134: .Jun 11 16:07:26: HTTPDNSUPD: Session ID = 0x43
001135: .Jun 11 16:07:26: HTTPDNSUPD: URL = '[email protected]/dynamic/update.php?U2lnOWswTVRTTUlBQUhTbmVvRTozNjI5NjQ1')">http://eugeneb:[email protected]/dynamic/update.php?U2lnOWswTVRT...'
001136: .Jun 11 16:07:26: HTTPDNSUPD: Sending request
001137: .Jun 11 16:07:26: HTTPDNSUPD: Response for update not4u.ignorelist.com <=>
001138: .Jun 11 16:07:26: HTTPDNSUPD: DATA START
is shared privately, therefore you may freely create however the domain owner has reserved their right to approve or deny your request, and should be considered non-permanent until that point.
You may also browse/attach to thousands of other shared domains listed here in the http://freedns.afraid.org/domain/registry/>Free DNS Domain Registry including those domains which are public and do not require any domain owner approval
If you have domains of your own, and are not already using http://freedns.afraid.org/>Fr
001139: .Jun 11 16:07:26: HTTPDNSUPD: Response for update not4u.ignorelist.com <=>
001140: .Jun 11 16:07:26: HTTPDNSUPD: DATA START
ee DNS to run their DNS, then you should check out what we can do for you.
Hosting your domains here allows you to still keep your current webhost with much greater control at the DNS level. Try using our powerful instantaneous DNS administration panel, and let it speak for it's self!
If you own this domain, you can instantly configure your domain to route to any IP/URL of your choosing from within the members area at anytime by navigating to the http://freedns.afraid.org/subdomain/>Free DNS Subdomains section. This is the default page for a new domain addition.
DNS is our business... 24/7. http://freedns.afraid.org/>Free DNS benefits
http://freedns.afraid.org/>Free DNS is currently processing 990 DNS requests per second.
001141: .Jun 11 16:07:26: HTTPDNSUPD: Response for update not4u.ignorelist.com <=>
001142: .Jun 11 16:07:26: HTTPDNSUPD: DATA START
001143: .Jun 11 16:07:26: HTTPDNSUPD: DATA END, Status is Response data recieved, successfully
001144: .Jun 11 16:07:26: HTTPDNSUPD: Call returned SUCCESS, update of not4u.ignorelist.com <=> succeeded
001145: .Jun 11 16:07:26: DYNDNSUPD: Another update completed (outstanding=0, total=0)
001146: .Jun 11 16:07:26: HTTPDNSUPD: Clearing all session 67 info
Paolo Bevilacqua Thu, 06/11/2009 - 09:56
If you think it should work, but it doesn't, you should contact the TAC, so they can either suggest a working config, or file a bug as necessary.
I experience the same problem, I see the HTTP request to freedns.afraid.org is sent with a HTTP Host header set to the IP address of freedns.afraid.org, this is causing the trouble. The response is easily reproduced using wget:
wget -q -O - --headers "Host: freedns.afraid.org" 'http://freedns.afraid.org/dynamic/update.php?XYZ...'
works correctly, while
wget -q -O - --header "Host:" 'http://freedns.afraid.org/dynamic/update.php?XYZ...'
does not work and reproduces the response mentioned above.
Excuse my dump question: Who is the TAC?
taherudin Thu, 08/06/2009 - 22:18
dear freind
i was trying to configure in cisco 877/K9 but it dont work can post your config Dyndns ?, will be appreciable
no problem - here you go, enjoy
add [email protected]/nic/update?system=dyndns&hostname')">http://eugeneb:[email protected]/nic/update?system=dyndns&hos...
interval maximum 1 0 0 0
interface FastEthernet0/1
ip dhcp client client-id ascii not4me
ip dhcp client hostname not4me
ip ddns update not4me host members.dyndns.org
ip address dhcp
ip access-group Wan-Deny in
no ip redirects
no ip unreachables
no ip proxy-arp
ip nbar protocol-discovery
ip nat outside
no ip virtual-reassembly
duplex auto
speed auto
no cdp enable
crypto map Stealth
ip access-list extended Wan-Deny
permit udp any eq bootps any eq bootpc
permit icmp any any
permit tcp any any established
permit ahp any any
permit esp any any
permit icmp any any echo-reply
permit icmp any any time-exceeded
permit icmp any any unreachable
permit udp any eq domain any
permit tcp any any eq 22
permit udp any any eq isakmp
permit udp any any eq non500-isakmp
permit tcp any any eq 4500
permit tcp any any eq 10000
permit udp any any eq ntp
permit tcp any any eq 5223
permit udp any any range 3478 3479
permit udp any any eq 28960
permit tcp any any eq 8000
