Power outage, now Cisco 851 will not operate properly
Jun 9th, 2009
There was a power outage today and my 851 is not stuck is some weird bridge mode. I cannot communicate with the router over Ethernet.
It is connected to a cable modem and it appears to be allowing the IP from the modem through and the internet works, however the routing does not.
I have tried to reset and reboot the machine multiple times. No luck.
Does anyone have any suggestions?
Thank you!
Mike
Overall Rating: 5 (1 ratings)
mikieboyblue Tue, 06/09/2009 - 17:55
Turns out I was able to find the console cable. I do not have any IOS images and I was unaware something catastrophic could happen (flash being wiped out after power outage). I am getting the following:
Copyright (c) 2005 by cisco Systems, Inc.
C850 series (Board ID: 4-149) platform with 65536 Kbytes of main memory
No bootable image file: flash:/
Unable to open boot file
System Bootstrap, Version 12.3(8r)YI2, RELEASE SOFTWARE
rommon 1 >
mikieboyblue Tue, 06/09/2009 - 18:40
Thanks for the reply Leolaohoo. The problem is, I don't have a IOS image because I never knew I needed make my own backup of IOS because it was not provided in any way with the product other than on the router.
I think I need to figure out how to get IOS.
Leo Laohoo Wed, 06/10/2009 - 16:09
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Thanks for the ratings Mike.
