no ping between from remote site (L2 VPN)
Jun 9th, 2009
Hi All,
I use 3750 router in the main office. 3550 Switch in the remote location. There is a L2 VPN 100 mbps connection b/w these two site.
Main Site router has two interface with the network address :192.168.1.0/24
172.22.100.0/24
192.168.1.0/24 is used in the main office
172.22.100.0/24 is used in the remote office.
Unable to ping from 192.168.1.0/24 to 172.22.100.0/24.I am able to ping 192 network from 172 network.
I also attched the configuration details.
Thank you,
Overall Rating: 5 (1 ratings)
John Blakley Wed, 06/10/2009 - 05:40
The attachment didn't come through, but you should check the 192 switch's routing table to make sure that it knows how to get to the 172 subnet.
HTH,
John
EPHRAIM MANI Wed, 06/10/2009 - 07:46
Please make sure the gateway is confgured correctly on the host in network 192.168.1.0 and 172.22.100.9. the gatway should be the ip address of the two interface (main and remote office )
