2821 2 HWIC cards
Jun 9th, 2009
Dear Experts,
I tried to install 2 HWIC 4ESW modules to 2821 routers. But only one slot working properly 2nd one shows everything fine but cannot ping or layer 3 activity not showing. But according to Cisco website it suggest 2 HWIC we can install. Is it a default behavior ( only one HWIC 4ESW work ) Any idea ?
Overall Rating: 5 (2 ratings)
arulgobi1 Tue, 06/09/2009 - 21:48
Seems to be we must enable stacking. With stacking it worked. otherwise it doesn't work :(
Paolo Bevilacqua Tue, 06/09/2009 - 23:13
  • Hall of Fame,
    Founding Member
That is documented by cisco, multiple ESW modules require a physical cabling across.
