Attendant Console - Window to front on incoming calls
Jun 9th, 2009
Hi - We are running CUCM6.1 and attendant console. Is there a way to stop the console fron popping up every time an incoming call arrives? I can't find any mention of it in the doco, but don't remember it donig it when using CCM4.1.
Overall Rating: 5 (1 ratings)
rob.huffman Wed, 06/10/2009 - 04:36
Hi Matt,
Have you tried to use this method to enable / disable "Pop to Top" on AC
Note: To toggle the pop-to-top feature on and off, press Alt + P.
From this doc;
There is also another method listed nicely by Met (with screenshot) here;
Hope this helps!
