Cisco ASA 5505 port forward to server proxy ( no wccp )
Jun 10th, 2009
Hi all,
I've read few old post about the redirect of 80 443 to a server-proxy with wccp. This solution is the only to forward port ? I think exists a more simple solution to forward a port, does it exists ?
For example how could I do to forward the 22 port to another host in my inside-lan to 222 ?
Thanks to all for reply.
ldardon Tue, 06/16/2009 - 13:00
To allow access to particular TCP port forwarding applications for a specific user or group policy, use the listname you create here with the port-forward command in webvpn mode. The security appliance does not support the Microsoft Outlook Exchange (MAPI) proxy. Neither port forwarding nor the smart tunnel feature that provides application access through a clientless SSL VPN session supports MAPI. For Microsoft Outlook Exchange communication using the MAPI protocol, remote users must use AnyConnect.
seibertmedia Wed, 09/30/2009 - 03:27
do you mean, portforwarding from external ip to an internal server behind nat?
Then, you can do a static NAT with PAT for the server
access-list internal_nat_static_3 extended permit tcp host $internal-host eq $port any
static ($internal-interface,$external-interface) tcp $external-ip $port access-list internal_nat_static_3
if you want to redirect packets from internal ip's you need policy based routing, which isn't supported by the asa.
