06-10-2009 12:12 AM
Dear,
CiscoWorks HUM stopped polling devices and generating reports since 11 AM yesterday. I tried to run the configured poller again but I got this error:
"Cannot communicate with Poller Manager Service. Check whether the UPMProcess is down.". I read the release notes for HUM and issued pdexec UPMProcess from the cmd prompt and got this result:
"ERROR: cmd failed. Server reason: Application UPMProcess is not registered. All requests to operate on this application will be ignored."
what can I do to solve this problem?
Solved! Go to Solution.
06-11-2009 08:44 AM
According to this, HUM is not installed on this server. If it used to be installed, it appears someone uninstalled it (or at least partially uninstalled it). Try reinstalling HUM.
06-10-2009 08:50 AM
Please post the output of the pdshow command.
06-10-2009 11:07 PM
06-11-2009 08:44 AM
06-12-2009 01:20 AM
I reinstalled HUM and tried to access it from the LMS portal but it gave me the error message that it could not connect to the database because UPMDbEngine process was down. I tried to restart this process using pdexec UPMDbEngine on the command line but it took forever to execute it. Then I uninstalled HUM completely and did a fresh install and that seems to solve the issue. Now HUM is working fine. Thank you very much for your help.
Abebe Amare
Systems Engineer, Vivacell
