ike phase 1 lifetime, asa with netscreen
Jun 10th, 2009
Hi all
Ipsec, L2L, in configuration I set 8h, on both side
IKE Peer: x.y.z.w
Type : L2L Role : initiator
Rekey : no State : MM_ACTIVE
Encrypt : 3des Hash : SHA
Auth : preshared Lifetime: 28800
Lifetime Remaining: 24897
but in logs, keys are changing in every 6 hours:
Jun 6 11:17:46 masterasa Jun 06 2009 11:17:46: %ASA-4-713903: Group = x.y.z.w, IP = x.y.z.w Freeing previously allocated memory for authorization-dn-attributes
Jun 6 17:17:46 masterasa Jun 06 2009 17:17:46: %ASA-4-713903: Group = x.y.z.w, IP = x.y.z.w, Freeing previously allocated memory for authorization-dn-attributes
Jun 6 23:17:46 masterasa Jun 06 2009 23:17:46: %ASA-4-713903: Group = x.y.z.w, IP = x.y.z.w , Freeing previously allocated memory for authorization-dn-attributes
Jun 7 05:17:47 masterasa Jun 07 2009 05:17:47: %ASA-4-713903: Group = x.y.z.w, IP = x.y.z.w, Freeing previously allocated memory for authorization-dn-attributes
Someone knows what's reason of that ?
thanks
srue Wed, 06/10/2009 - 07:53
i've never seen that before, especially if the lifetime is the same on both sides.
what is the output of "show isa sa detail" on the cisco equipment, and the equivalent output on the other hardware?
pawel1942 Fri, 06/12/2009 - 06:01
it's my sh crypto isakmp sa detail
IKE Peer: x.y.z.w
Type : L2L
Role : initiator
Rekey : no
State : MM_ACTIVE
Encrypt : 3des
Hash : SHA
Lifetime Remaining: 12134
my conf:
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 28800
On the netscreen side is exactly the same
i don't have any idea what's the reason of this
greetings
Pavel
