Autoupdate IPS signature not working
I am getting the following on the IPS auto-update
Auto Update Statistics
lastDirectoryReadAttempt = 02:30:00 Eastern Tue Jun 09 2009
= Read directory: http://198.133.219.25/pcgi-bin/tablebuild.pl/ips6-sigup
= Error: http error response: 400
lastDownloadAttempt = N/A
lastInstallAttempt = N/A
nextAttempt = 02:30:00 Eastern Wed Jun 10 2009
lastDirectoryReadAttempt = 02:13:00 Eastern Wed Jun 10 2009
nextAttempt = 02:13:00 Eastern Thu Jun 11 2009
Can you tell me what I am doing wrong.
abinjola Thu, 06/11/2009 - 22:59
  • Cisco Employee,
is management IP getting routed through ASA inside interface ? if yes then kindly get me the packet captures
access-list abc permit ip host host 198.133.219.25
access-list abc permit ip host 198.133.219.25 host
capture cpi access-l abc interface
Intf.Name-->INterface on ASA which is part of same VLAN as IPS Mngmt IP
Also send me the latest show statistics host
George Thomas Tue, 06/23/2009 - 13:33
  • Blue, 1500 points or more
To add to the wonderful comment by Ashish, I had the same problem and fixed it by changing the "//" after the IP address to "/".
bbiandov Wed, 02/12/2014 - 10:10
What was is the CORRECT current URL which actually works in the real world; NOT lifted off some wrong documentation? I mean working URL - copy and paste from a working setup please?
Naveen Kumar Thu, 02/13/2014 - 23:21
  • Silver, 250 points or more
Update the Auto Update URL Using the CLI (all other IPS versions)
NOTE: Do not change the double slash (//) at the end of the IP address shown in this configuration.
sensor#<strong>config t</strong><br/> sensor(config)#<strong>service host</strong><br/> sensor(config-hos)#<strong>auto-upgrade</strong><br/> sensor(config-hos-aut)#<strong>cisco-server enabled</strong><br/> sensor(config-hos-aut-ena)#<strong><span>cisco-url </span><a class="jive-link-external-small" href="https://72.163.4.161//cgi-bin/front.x/ida/locator/locator.pl">https://72.163.4.161//cgi-bin/front.x/ida/locator/locator.pl</a></strong><br/> sensor(config-hos-aut-ena)#<strong>exit</strong><br/> sensor(config-hos-aut)#<strong>exit</strong><br/> sensor(config-hos)#<strong>exit</strong><br/> Apply Changes?[yes]:<strong>yes</strong>
