06-10-2009 06:30 AM - edited 03-15-2019 06:27 PM
If I install DMA 7.1 and export the database from CM 4.1 can I restore/migrate on CM 6.1.3 ? OR I can do restore that only in CM 7.x.
I could not find anything related to this in release notes for DMA.
Thanks for your help.
06-10-2009 12:47 PM
DMA is tied to the version
if you have 7.1, it's for CUCM 7.1
If you have DMA 6.1(3), then use it in a CUCM 6.1(3)
java
if this helps, please rate
06-10-2009 12:49 PM
Thanks..I just want to double check before I do the upgrade.
