WiSM initial config
Jun 10th, 2009
Okay so I have the initial config on the controllers but I cannot ping the management interfaces.
Well that is to say the controllers cannot ping the default gateway.
Is it a tagging issue across the trunk maybe?
(WiSM-slot2-1) >show interface summary
Interface Name Port Vlan Id IP Address Type Ap Mgr Guest
ap-manager LAG 778 Static Yes No
management LAG 778 Static No No
service-port N/A N/A Static No No
virtual N/A N/A Static No No
(WiSM-slot2-1) >
scott.hammond Wed, 06/10/2009 - 06:37
yep, answered my own question. The native on the CAT side needed to be VLAN 1
Thanks anyway.
weterry Wed, 06/10/2009 - 19:21
Alternately, if 778 was the native vlan for the link, the configuration would be to untag the management and AP-Manager (vlan 0).
