SPA9000 AA On Timeout to Reception
Jun 10th, 2009
Just wondering if there is a way you can setup the AA on the SPA9000 to instead transfer to an extension when there is no response/no input made into the AA. For example a End User could have "Welcome to XYZ, enter an extension number or hold for reception". I have tried placing an xfer statement within a No Input statement, however the AA just rings out.
Is it possible to do this and if so do you have a recommended way of doing this?
David
Alberto Montilla Mon, 06/15/2009 - 09:56
  • Cisco Employee,
Hi David;
Yes, it is possible.
I suggest you check the SPA9000 Administration Guide (in the documentation section of this community) for complete syntax.
You effectively need to use the No Input statement
repeat=”T”>
Alberto
