Sorry Server in another context.
Jun 10th, 2009
Dear Mister
Is possible to do this. In case that I have two servers belong to serverfarm. If the two servers going down, is possible to create a "sorry server" in a server in another context?? In the same context I understand that function ok, but in another context not.
A tricky??
Best Regards
Kristopher Martinez Wed, 06/10/2009 - 08:07
  • Cisco Employee,
Rodrigo,
The ACE contexts are isolated from each other. You could use a sorry server in another context, but you would have to go to another device to bridge or route the traffic to the other context. This means getting creative with the traffic routing using VRFs and NAT. This would create a bridge between your two ACE contexts. If they are in separate security zones you would not want to do this.
It would be best to create a local sorry server for this context to use.
Kris
