how to upgrade 4006 rommon
Jun 10th, 2009
After upgraded 4006 IOS, system has a BIG error says "your rommon versio obsolete"...
4006 + supIII
ios is cat4000-i5k91s-mz.122-25.EWA14
Please where can i download rommon and how to upgrade it...
Overall Rating: 4 (2 ratings)
rico_hao40 Wed, 06/10/2009 - 08:05
After I upgraded IOS then I reload the 4006, after that it showing that error...
sachinraja Wed, 06/10/2009 - 08:23
4006 is a very old product, and not sure if you would have updates on CCO, for the IOS releasess.. In any case for 12.2(25) IOS, you might require a minimum of 12.2(31r)SGA3 ROMMON.. You can downloading the file " ios-promupgrade-122_31r_SGA3 " and see if it solves your issue. CCO shows only ROMMON compatibility information with regards to 4500 series switches as given in this URL:
Hope this helps.. All the best..
