George Stefanick Fri, 06/12/2009 - 04:43
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, October 2015
Did you lose your wep key?
George Stefanick Fri, 06/12/2009 - 06:25
You still may be in luck. If anyone of your wireless clients used Windows Zero Config then simply run WZCOOK. Your WEP key is stored in the reg.
I created a video how to do it:
http://www.my80211.com/security-labs/2009/1/10/do-you-use-windows-zero-config-as-your-wlan-client-managemen.html
If you didnt use windows zero config, you can use Aircrack to break the key. Run Aircrack while downloading a ISO over wireless. You can get the key in a few minutes.
i hope this helps ...
George Stefanick Fri, 06/12/2009 - 08:40
no problem. if you need a hand breaking the key, contact me via the web site i will be happy to help. if you found this post helpful please rate it ...
thanks
Trending Topics - Security & Network
