Remote Access Dail-In server
Jun 10th, 2009
Hello all,
I have cisco 2851 routers, the output ogf show version
Cisco IOS Software, 2800 Software (C2800NM-SPSERVICESK9-M), Version 12.4(15)T7,
RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Wed 13-Aug-08 17:09 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
Cisco 2851 (revision 53.51) with 249856K/12288K bytes of memory.
Processor board ID FHK1308F39S
2 Gigabit Ethernet interfaces
24 terminal lines
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
The modules details in used:
HWIC-2CE1T1-PRI
With
PVDM2-24DM
Our E1 link in terminated on this 2851 router, and as our branch offices will dial up for the remote access to this router. We are in doubt on configuration does it support or not.
If it does, then please someone help me in this. We will really appreciate for your help.
paolo bevilacqua Wed, 06/10/2009 - 13:21
  • Hall of Fame,
    Founding Member
Yes, it does.
It is quite strange for branch offices to use modem dial-up, because it is so slow. You would do better with broadband access and VPN like everybody else does nowadays.
If you need help in configuration I suggest you locate a competent consultant or cisco partner.
urs.shrestharana Thu, 06/11/2009 - 21:29
Thank You for you quick response on this case. We also one of partners. Its a known issue of dial-up but its the requirement so we are trying to set up.
For that requirement, we have
A router with 2851 with modules
HWIC-2CE1T1-PRI and PVDM-24DM
On this case, we are not being able for channelizing the E1 controller and as it shows 24 Async Interface on command
sh ip int brf
That is making us on confusion on configuration so we would like to put forward this case to all, so that can get the clear documents related. Hoping for needful help.
urs.shrestharana Thu, 06/18/2009 - 02:12
Hello
Well , we are still on some confusion on setting this E1 RAS on cisco 2851, issues are:
- E1 link whenever connected to HWIC 2CE1T1 PRI module of cisco 2851, line status will be busy.
******issued check - physical layer
***Checked all the phases of link as we have Patton RAS 2960, the same link works.
requirement is:
We want do use dial up to access remote network, we have
HWIC 2CE1T1 PRI
PVDM 24DM
Cisco 2851
SH ver--- attached
We have got configured but still not functionable, so please can anyone provide any information on our configuration. I will be very kindful for your help.
paolo bevilacqua Thu, 06/18/2009 - 03:16
  • Hall of Fame,
    Founding Member
You do not have anything under controller E1, configure pri-group or E1 R2 as needed.
urs.shrestharana Thu, 06/18/2009 - 05:56
Hello paolo
I am confused on dial up services and isdn service, as requirement is
- User dials from anywhere to cisco 2851 E1 RAS for accessing the network resources behind our RAS.
As known from the cisco documentation and doing -to configure pri-group or E1 R2 we are required to enable ISDN switch type. Doing configure shows as follow:
RTR(config-controller)#pri-group timeslots 1-31
%ISDN switch-type must be set first.
Is ISDN required to match our requirement.
It's a great help for me fro you,, i really appreciate for you help.
paolo bevilacqua Thu, 06/18/2009 - 10:32
  • Hall of Fame,
    Founding Member
Ask your telco, if you have ISDN PRI or E1 R2.
urs.shrestharana Thu, 06/18/2009 - 22:58
Hello Paolo
Thanks for you response, i really appreciates for your help.
As our telco services, we have E1 R2 but command required for R2 signalling DS0 group not acceptable by router.
Only commands available under Controller is:
xxxx(config-controller)#?
Controller configuration commands:
bert Start BERT test
channel-group Specify the timeslots to channel-group mapping for an
interface
clock Specify the clock source for a DS1 link
default Set a command to its defaults
description Controller specific description
exit Exit from controller configuration mode
framing Specify the type of Framing on a E1 link
guard-timer Guard timer (0-20) for xcsp calls - timer duration and
accept/reject on expiry
help Description of the interactive help system
line-termination Specify the line termination for E1
linecode Specify the line encoding method for a E1 link
loopback Put the entire E1 line into loopback
national Set E1 National Reserve Bits.
no Negate a command or set its defaults
pri-group Configure the specified timeslots for PRI
shutdown Shut down a E1 link (send Blue Alarm)
snmp Modify SNMP controller parameters
tdm-group Configure DS0 group for TDM
Can you please update any information in this issue, how to add E1 R2 Signalling under this controller?
Waiting for further update.
paolo bevilacqua Fri, 06/19/2009 - 00:36
  • Hall of Fame,
    Founding Member
Change ios image to "ip voice".
urs.shrestharana Fri, 06/19/2009 - 01:11
Hello Paolo
Actually, we are using for data not for voice thats why we have updated the IOS with this version. After looking on cisco dynamic configuration tool we came to know currently used IOS on our router
-(c2800nm-spservicesk9-mz.124
is-11.XW5.bin)-
doesn't support existing cisco router 2851 with E1 card (HWIC-2CE1T1-PRI)along with PVDM2-24DM modules, suggested IOS as per configuration tool is:
To correct this error REPLACE the S28NSPSK9-12411XW from the following options
(2800 SOFTWARE:SP SERV 2800:S28NSPSK9-12411XW)
Product Number and Description
S28NSPSK9-12415XY
Cisco 2800 SP SERVICES
(2800 SOFTWARE:SP SERV 2800:S28NSPSK9-12415XY)
S28NSPSK9-12415XZ
(2800 SOFTWARE:SP SERV 2800:S28NSPSK9-12415XZ)
S28NSPSK9-12420T
(2800 SOFTWARE:SP SERV 2800:S28NSPSK9-12420T)
S28NSPSK9-12420YA
(2800 SOFTWARE:SP SERV 2800:S28NSPSK9-12420YA)
S28NSPSK9-12422T
(2800 SOFTWARE:SP SERV 2800:S28NSPSK9-12422T)
S28NSPSK9-12424T
(2800 SOFTWARE:SP SERV 2800:S28NSPSK9-12424T)
Is this what the problem is about? Among the specified IOS any one supported for our requirement? Hope for your response soon.
paolo bevilacqua Fri, 06/19/2009 - 02:24
  • Hall of Fame,
    Founding Member
Not sure. It may be that the HWIC doesn't support E! R2. Ask your telco if you can get ISDN PRI instead.
