Giuseppe Larosa Wed, 06/10/2009 - 13:07
  • Hall of Fame,
    Founding Member
Hello Francisco,
if you mean a L3 port channel supporting IPv4 and MPLS I personally prefer to use parallel indipendent L3 links.
The load balancing on L3 links should be based on the more internal MPLS label.
Increasing the mtu, mpls mtu of port-channel interface (and may be of member links) is needed.
If you mean increasing the MTU on a L2 port-channel connecting two switches this is needed too to support MPLS VPN traffic.
In this case of L2 port-channel load balancing could be based on the external label that points to remote PE (these are generally less variable then inner labels)
Hope to help
Giuseppe
francisco_1 Wed, 06/10/2009 - 13:40
  • Gold, 750 points or more
Thanks guys for your comments. To clarify my question sorry what i meant was is it supported to have LDP enable on L3 port-channel and the increase of MTU for the labels on the port-channel.I have a couple of 6509's as distribution and core switches with L3 port-channels between the switches. i would like to enable mpls on the L3 port-channel and increase the MTU for the labels.
