WSA - Changing ip and gateway
Jun 10th, 2009
Hi, did anyone try this changes?
WSA will have its ip changed including gateway.
Did anyone make it work without reloading the config or restore to factory default?
What will happened if im going to edit the config then replace only the ip address..
just asking
jowolfer Wed, 06/10/2009 - 17:43
As long as your client configuring the WSA and the WSA are on the same subnet, you can change the default gateway and then the WSA IP and you should have no problems, if you do it in that order.
You can also modify the config XML and load it back in, but this is an unsupported process.
