Dual vlan in CAT
Answered Question
Jun 10th, 2009
Hi, can i make a port part of dual vlan, that is data and voice in cat 6500 and 4006 series switches? i dont know how to.
i can do it easily in IOS bases switches.
need help
Correct Answer by garytayl about 8 years 2 weeks ago
If we are dealing with CATOS then you should be using the auxiliary vlan command:
set port auxiliaryvlan mod[/ports] {vlan | untagged | dot1p | none}
The auxiliary vlan here will be the voice vlan.
Hope it helps...
Overall Rating: 5 (1 ratings)
Correct Answer
garytayl Wed, 06/10/2009 - 10:53
  • Silver, 250 points or more
Hope it helps...
