Can't access management interface via vpn connection
Jun 10th, 2009
Hi all,
I can't seem to be able to manage my ASA 5510 when I connect via vpn. My asa sits at a remote colo, and from my office i can connect fine. I have it configured as management-access (dmz), bc as of now we are just doing some staging and all the servers are in the dmz interface.
When i connect with the vpn client, in the routes it sees 192.168.1.0 255.255.255.0 which is the management network/interface.
For some reason I can't get access to 192.168.1.1 to use the ASDM.
Here is how i did my vpn via CLI
isakmp enable outside
isakmp identity address
isakmp policy 10
authentication pre-share
encryption des
hash md5
group 2
lifetime 86400
ip local pool vpnpool 10.1.1.2-10.1.1.10
access-list split_tunnel standard permit 192.168.200.0 255.255.255.0
access-list split_tunnel standard permit 192.168.100.0 255.255.255.0
access-list split_tunnel standard permit 192.168.1.0 255.255.255.0
group-policy xxxxx internal
group-policy xxxxx attributes
dns value
split-tunnel-policy tunnelspecified
split-tunnel-network-list value split_tunnel
username xxxxx password
username xxxxxx attributes
vpn-group-policy xxxx
username xxxxxx password
username xxxx password
username xxxx attributes
tunnel-group xxxx type ipsec-ra
tunnel-group xxxx general-attributes
address-pool vpnpool
tunnel-group xxxx ipsec-attributes
pre-shared-key
access-list vpnra permit ip 192.168.200.0 255.255.255.0 10.1.1.0 255.255.255.0
access-list vpnra permit ip 192.168.100.0 255.255.255.0 10.1.1.0 255.255.255.0
access-list vpnra permit ip 192.168.1.0 255.255.255.0 10.1.1.0 255.255.255.0
nat (inside) 0 access-list vpnra
nat (dmz) 0 access-list vpnra
nat (management) 0 access-list vprna
crypto ipsec transform-set md5des esp-des esp-md5-hmac
crypto dynamic-map dynomap 10 set transform-set md5des
crypto map vpnpeer 20 ipsec-isakmp dynamic dynomap
crypto map vpnpeer interface outside
Any help would be much appreciated
proffessor1979 Wed, 06/10/2009 - 11:44
no I have that in there. see my first few lines. I configured management-access (dmz)
still can't use asdm through vpn. Could it be b/c of split tunneling is enabled or a binding issue? Not sure how to go about troubleshooting it.
Thanks for the reply
proffessor1979 Wed, 06/24/2009 - 10:39
anyone? Still can't get access, it's very frustrating as it seems like a simple thing yet it's not working
