VWIC2-2MFT-T1/E1 configuration with CCA??
Jun 10th, 2009
I'm trying to setup a VWIC card on the UC500, I'm using CCA 2.0 but when I'm trying to enable the VWIC card under "telephony" in CCA the area is greyed out. Any suggestions?
I guess I could use CLI, but the dial-plans could be a nightmare I belive.
Eivind
Marcos Hernandez Wed, 06/10/2009 - 09:49
Can you please post the CCA log when trying to configure this VWIC? (Press "F2" while executing the config steps).
Marcos
Marcos Hernandez Wed, 06/10/2009 - 10:34
As you can see from this output, IOS is seeing the card but CCA isn't. May I ask you to please open a TAC case? I am sure that if you add "card type t1 0 2" to the config, it will help, but it would be great if you could help us track this formally and determine if there is a bug here. This is very basic functionality that I am sure was tested. I don't know what could be wrong.
Marcos
Eivind Jonassen Wed, 06/10/2009 - 10:41
I would, but since the registration of the SMARTnet deals are taking so long to register from the dist to cisco, I am now going to have a big problem, since the customer is awaiting me with the deployment tomorr.
I'll see what I can do about this
Eivind
Marcos Hernandez Wed, 06/10/2009 - 10:46
Understood. Do what you can here. By the way, I meant "card type e1 0 2" since you are in The Old Continent :-)
Marcos
Eivind Jonassen Wed, 06/10/2009 - 10:47
Marcos,
I'm not able to add the command to the config... only "carrier-id" is availiable from the command list
/Eivind
Marcos Hernandez Wed, 06/10/2009 - 10:51
Eivind,
A couple of my teammates just caught this:
From the sh diag, this is a two port T1 VWIC, which is not currently supported by CCA.
VIC Slot 2:
VWIC2-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1
I overlooked this initially. We only support the 1 port T1/E1 VWIC.
Marcos
Eivind Jonassen Sat, 06/13/2009 - 08:13
Marcos,
Got the correct VWIC installed, but after a configruing the system, after a while the voicemail dial-peer stopped working. I used CCA, web and CLI, so not sure what's happened here. If I dial the VM ext i get "no codec" from the "debug ccsip calls". If I dial from the outside towards the AA i get the following errors from "debug ccsip error", I also get "no codec" message;
000615: Jun 13 13:35:05.491: //-1/xxxxxxxxxxxx/SIP/Error/HandleUdpSocketWrites: Send failed errno 261
000616: Jun 13 13:35:05.491: //-1/xxxxxxxxxxxx/SIP/Error/act_socket_send_msg_failure: Send Error to 10.1.10.1:5060 for transport UDP
000617: Jun 13 13:35:05.491: //-1/xxxxxxxxxxxx/SIP/Error/sipSPIGetContentQSIG: No Inbound Container Created !!!
000618: Jun 13 13:35:05.491: //-1/xxxxxxxxxxxx/SIP/Error/sipSPIGetContentQ931: No Inbound Container Created !!!
000619: Jun 13 13:35:05.491: //32/D671E4768062/SIP/Call/sipSPICallInfo:
The dial-peer for the voicemail is :
dial-peer voice 2000 voip
description ** cue voicemail pilot number **
destination-pattern 999
b2bua
voice-class sip outbound-proxy ipv4:10.1.10.1
session protocol sipv2
session target ipv4:10.1.10.1
dtmf-relay sip-notify
codec g711ulaw
no vad
This is software pack 7.0.3, and I see that the " voice-class sip outbound-proxy ipv4:10.1.10.1" command is new. Tried to remove it, but didn't help much.
Any idea of what's happened ???
Eivind
Marcos Hernandez Sun, 06/14/2009 - 06:47
This could be caused by a dial-peer matching problem. Can you post your full configuration? As usual, remove passwords and public IP's.
Marcos
Eivind Jonassen Mon, 06/15/2009 - 08:26
Marcos,
I did some troubleshooting today and enabled "debug dialpeer all", I then called AA and it came back up and everything is working now. Don´t know what the root of the problem was, but it works now anyways. :)
Eivind
