DTMF out-of-band on MGCP
Jun 10th, 2009
I would like to configure dtmf out of band for an issue I may be having on an MGCP gateway. The gateway, however, does not have dial-peers. MGCP gateways that are configured via cluster used to have dial-peers numbered in the 9XX range, I believe, but I've found that in more recent revisions that this is not the case. Does anyone know how this has changed and what recourse I have for this issue?
shikamarunara Wed, 06/10/2009 - 09:55
There's an MGCP command;
mgcp dtmf-relay voip codec all mode out-of-band
That appears to be an equivalent. Is this what it is for?
parshah Wed, 06/10/2009 - 09:59
  • Cisco Employee,
that command will do that trick.
thanks
harris.h Wed, 06/10/2009 - 10:24
Hi There
This may or may not be applicable,
taken from another forum post:
CSCso87127 in-band DTMF leakage of 40-50msec observed when using DTMF relay
May be worth checking out.
Nicholas Matthews Wed, 06/10/2009 - 17:26
  • Red, 2250 points or more
In all circumstances, the gateway will send a NTFY with D/.
This command allows for it to advertise the capability to CUCM and for CUCM to know to forward it on.
If you use 'ccm-manager config' this is an automatic configuration.
You can use 'debug mgcp packet' and you should see NTFY messages with the line D/1, D/2, etc in it.
-nick
