Connect PA-system to UC500 in a grocery store?
Jun 10th, 2009
Hi!
I'm looking for a way to use the intercom feature on the UC500 to broadcast on a grocery stores PA-system. I'd figure it would be a easy thing to fix but I can't seem to find any way to connect the PA-system, did'nt find any plug & play box on google. Any ideas?
The PA-system has 3,5mm and RCA input.
Thanks!
jaydien1358 Wed, 06/10/2009 - 11:12
Maybe you could find a phone with audio outputs to interface with the PA?
What about a paging system that has anolg phone interface?
Brian
m.junghage Thu, 06/11/2009 - 04:33
Thank you!
I looks like the things I need, had a hard time finding a Swedish retailer though. Anyone know where I can get these brands in Sweden?
I connected a pair of computer speakers to the headset jack of my 7941 with a GN headset cord Modular->3,5mm and it worked. The downside is that the headset button need to be selected att all time for the intercom signal to go through to the speakers.
Marcos Hernandez Thu, 06/11/2009 - 05:56
I couldn't really tell you who to contact. Probably each vendor has local retailer info?
Marcos
