1242 Bridge/NonRoot Bridge
Jun 10th, 2009
Is it possible to use EAP-FAST between root and nonroot bridge with 1242's and local radius? I can get LEAP WPA2 to work but I cannot get EAP-FAST to work. Ideas?
Robert.N.Barrett_2 Wed, 06/10/2009 - 12:51
  • Bronze, 100 points or more
I would suggest you consider using WPA2 with a 64 random character *HEX* key.
You can even get the key from here:
https://www.grc.com/passwords.htm
This means you don't need to use LEAP or EAP-FAST to authenticate the NonRoot bridge - just the complex hex key on WPA2 with Open Authentication.
wackerk24 Wed, 06/10/2009 - 12:56
Thanks for the suggestion. In this case I have to do EAP and would like to know all of my options. I was able to get EAP-FAST to work using an external radius server but when using the local radius server on the ap I cannot get EAP-FAST to work. Ideas?
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
