stephen2615 Wed, 06/10/2009 - 23:55
The very first setup of these systems and subsequent password changes enforce relatively strong passwords and wont let normal words be used so I would seriously doubt it will be anything simple like that.
You are going to need to find another way onto it.
chris.walden Wed, 06/24/2009 - 07:30
There is no 'default' password. Right out of the box, it will prompt you to pick a password. If you can't log in, you will need to do a password recovery (your OSM can help with this if you need it).
Trending Topics: Storage Networking
