Static Route Between Linksys RV082 and Cisco 2821 Router
Jun 10th, 2009
My configuration is a Linksys RV082 Dual-Wan Router that gets the two incoming internet connections and then on the switch port of the RV082 I have a Cisco 2821 connected. I need to know how to configure the RV082 to route all incoming/outgoing to the lan(2821) and internet.
The ip's are as follows:
Linksys LAN Interface-
Cisco LAN Interface-
Cisco WAN Interface-
mmacdonald70 Thu, 06/11/2009 - 03:16
If you don't want to use RIP, you could create:
Linksys -> 192.168.0.x (Cisco interface)
Cisco ->
You might also need to tell the Linksys to also nat any other networks that you are using (
