Implication of removing portfast,bpduguard from production switch
Answered Question
Jun 10th, 2009
Folks, I have a number of switches and ports configured as shown below. Request is that I should remove such portfast and stp bpduguard and bpdufilter configurations from production switches.
Question:
My concern is that such switches are live, critical and I have a bunch of live hosts connected to it.
Do you see any potential issue that could be triggered when removing configuration below? I just want to confirm.
interface FastEthernet0/1
switchport mode access
no keepalive
spanning-tree portfast
spanning-tree bpdufilter enable
spanning-tree bpduguard enable
Correct Answer by iyde about 7 years 10 months ago
If your network is connected to an ethernet based ISP network you would not want your Spanning Tree to be influenced by the ISP Spaning Tree and vice versa. In that case both you and the ISP will put bpdufilter on the interface that interconnects you.
Correct Answer by glen.grant about 7 years 10 months ago
If any of these ports are user devices I don't think you want to turn off portfast. This can cause dhcp issues or any device that has to boot off of something on the network.What did they give as the reason to turn them off . Normally you do not want to run bpdufilter and bpduguard at the same time so maybe thats the issue .
Overall Rating: 5 (2 ratings)
Correct Answer
glen.grant Wed, 06/10/2009 - 14:42
  • Purple, 4500 points or more
Jon Marshall Wed, 06/10/2009 - 14:50
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Marlon
I think Glen is spot on with this. Turning off portfast can create problems with devices that need "immediate" network connectivity. In addition BPDUGuard is also a very useful feature to enable on a port where you do not expect to see any BPDUs.
Is there any reason you need to remove these ?
Jon
Giuseppe Larosa Wed, 06/10/2009 - 23:45
  • Hall of Fame,
    Founding Member
Hello Marlon,
I agree with Glen and Jon.
I would remove only
as explained in other thread of yours it is not the right tool for this kind of ports.
I think that removing STP portfast making a port a normal port can trigger a Topology change notification that causes STP recalculation.
to do this on multiple ports triggers a series of STP recalculations.
It is probably better to discuss again about the objectives of this action.
Hope to help
Giuseppe
news2010a Fri, 06/12/2009 - 10:26
I totally agree. I asked folks around it sounds like that was just a misperception about problems.
Curiosity:
Can someone clarify in which specific scenario 'bpdufilter' would be used?
I read the documentation and I understand the effect of bpdufilter, but to this point I have not seen an example on where I could use it.
Correct Answer
iyde Fri, 06/12/2009 - 22:32
  • Silver, 250 points or more
