Route-map Global policy
Jun 10th, 2009
Hi, I want two global policies-
1. All ICMP reply should come from L0
2. All telnet Reply should come from L0
ICMP reply is working fine, but I am not getting telnet reply from L0. Please help.
access-list 101 permit icmp any any
access-list 101 permit tcp any any eq telnet
route-map RR permit 10
match ip address 101
set interface Loopback0
ip local policy route-map RR
srimural Wed, 06/10/2009 - 23:01
Hi Rupesh,
is there any particular reason you want to achieve the same using a route-map.Else you can use
ip telnet source-interface loopback0
Srinath M
+91 99809 30364
Rupesh Kashyap Wed, 06/10/2009 - 23:17
"ip telnet source-interface loopback0" will work if self router (R1) is generating telnet traffic for others. Here many hosts wants to telnet on R1 & R1 should always reply with its L0 address.
srimural Wed, 06/10/2009 - 23:42
oh ok ok.. now got it.. so u want when u telnet from a host.. reply to go from the loopack 0..
Rupesh Kashyap Thu, 06/11/2009 - 01:02
Yes. any ICMP is working as per policy, only Telnet is not touching the ACL or Route-map
Richard Burts Thu, 06/11/2009 - 04:08
I am still not clear about what you are attempting to do. But I believe that the reason that ICMP does work and Telnet does not work is that your access list is identifying Telnet as the destination port. I believe that it would work if you identify Telnet as the source port. So rewrite the access list to look something like this:
access-list 101 permit tcp any eq telnet any
