ASA5510 active/standy - using the aux port
Answered Question
Jun 10th, 2009
Does the ASA allow you to use the aux port to access the console port on another device? I used to do this with IOS routers, but I can't find any docs to support this with the ASA. I'd like to be able to console a standby asa via the aux port the active ASA
TIA
Correct Answer by srue about 8 years 2 weeks ago
no, this is not possible with the ASA. the ASA has no telnet client, which is how the IOS feature that you're looking for is used.
Overall Rating: 5 (1 ratings)
Correct Answer
srue Thu, 06/11/2009 - 05:25
  • Blue, 1500 points or more
