high delay when traffic passes through the tunnel
Jun 10th, 2009
i have a dmvpn topology, .
When i try to ping the real ip on the hub's outside interface from the spoke, the delay is approximately 100ms, but when i ping the tunnel ip address the delay becomes 4000ms.
Your help is really appreciated
Farrukh Haroon Thu, 06/11/2009 - 02:25
Can you post the configuration?
Did you set the MTU of the tunnel interface correctly?
Also check the switching (CEF/Process Switching) configuration.
