PAP2T-EU
Jun 11th, 2009
Hello All!
I use CM 6.1.
I try connect PAP2T-EU to CM...
I have not expirience work with Linksys so I can not configure Linksys corret...
Can anybodu provide step by step configuration?
Thank you very much!!!
Patrick Born Thu, 06/11/2009 - 15:37
  • Cisco Employee,
Hi chernyakov,
Refer to the ATA Admin Guide for registration documentation. https://www.myciscocommunity.com/docs/DOC-2149
Here's a direct link: http://www.cisco.com/en/US/docs/voice_ip_comm/csbpvga/ata/administration/guide/ATA_AG_v3_NC-WEB.pdf
You should perform the following tasks, in order, so that you start from a known point:
1. Factory reset the device [page 226 in the "How do I access the ATA device if I forget my password?" section]
2. Upgrade to the latest firmware
3. Configure the device to register to your CM [starting on page 39 and then on to page 42]
Patrick
Mikhail Chernyakov Mon, 06/15/2009 - 01:04
Hello Patrick!
Thank you very much for useful links...
But I have some trouble...
Sopftware version of my device is 3.1.15(LS)
Is this latest version?
Where can I download new version?
Patrick Born Mon, 06/15/2009 - 10:03
  • Cisco Employee,
Hi chernyakov,
The current version of firmware is available from http://cisco.com/smallbusinessand then search on pap2t.
You need to log in as a guest, registered user, or partner in order to download firmware.
Patrick
Ordenador Mon, 06/22/2009 - 05:10
Hello, Patrick!
Thank you very much for useful links, but we have some troubles else...
When we dial some number, dialing process last 10 seconds, but we need it last max 3 seconds... How we can configure this parameter?
Patrick Born Mon, 06/22/2009 - 15:33
  • Cisco Employee,
Hi Ordenador,
You can modify the Interdigit Long Timer from 10 to a shorter time in seconds:
PAP2T web-ui > Regional > Control Timer Values > Interdigit Long Timer: 3
More information in the Admin Guide:
Patrick
