LMS 3.1 License management
Jun 11th, 2009
Hello all,
With menu Common Services > Software Center > Software Updates.
I select a license 100 devices ok -> LMS is register with 100 devices
Then I select a license 300 devices ok -> LMS is register with 300 devices
Then I select the first license 100 devices -> LMS is stil register with 300 devices devices.
My question is how delete the license 300 devices?
Don't see that is CS user guide.
yjdabear Thu, 06/11/2009 - 06:26
  • Gold, 750 points or more
Given the 100-device license is only sold for Windows, I'll assume that's the OS you're running LMS on.
1. Make sure your 100- and 300-dev license files are somewhere other than in NMSROOT\etc\licenses
2. From the Command Line, run:
pdterm LicenseServer
3. Go to the NMSROOT\etc\licenses folder and delete all *.lic files in there.
4. From CLI, run:
pdexec LicenseServer
5. Close all your browser windows. Open a new session to your LMS.
6. Point LMS to the 100-dev lic now.
