incoming call faild
Jun 11th, 2009
hi,
i've got a network with: a FTTH, a rvl200, a spa9000, and 12 ip phones (spa942 and 1 spa962).
some call didn't work.
for exemple : phones are ringing, they pic up the call ... and nothing no comunication.
i didn't know where is the trouble ...
thanx for your help
Loic
Patrick Born Thu, 06/11/2009 - 15:47
  • Cisco Employee,
Hi Loic,
What is a FTTH?
Can you describe which calls fail? Is there any pattern to call failures?
Take a look at http:///admin/status when calls fail. Are there any hung calls?
I glanced at your syslog file, but it's 5,800 lines long... can you start a new syslog file and then take note of the time of day when a call fails?
Then supply me with date and time, and something to help me locate the call information in the syslog please.
Is this a *very* busy system? How many simulataneous calls, AA access, conference calls?
Verify that the phones and the SPA9000 are using the most current firmware.
Do you not use voicemail? You don't mention SPA400 devices.
Patrick
proximao87 Tue, 06/16/2009 - 02:51
sorry for my delay.
A FTTH is a fiber to the home , perhasps is a french "touch" ^^.
I make some change.
I create a hung group instead of multiple extension.
incoming call are ok,
but for outgoing call we have some "not available" on the phone ...
I don't know why ...
i put the option Call Capacity on unlimited but nothing change.
Loic
Patrick Born Tue, 06/16/2009 - 15:51
  • Cisco Employee,
Hi Loic,
I'm envious of you having fiber. I only get broadband cable where I'm at. :-(
Consider enabling debugging on the SPA9000 and then checking the resulting syslog logs to see if any clues are offered as to why some outbound calls fail.
https://www.myciscocommunity.com/docs/DOC-3032
If you are able, a Wireshark trace between the SPA9000 and the ITSP may provide clues as to why some outbound calls are failing/being rejected.
Could it be that your ITSP is limiting you?
Patrick
proximao87 Wed, 06/17/2009 - 01:26
My ITSP doesn't limit me.
i've got some log for you ...
perhaps you can see something.
Loic
