Desktop Supervisor...no Agent Stats report data
Answered Question
Jun 11th, 2009
I am running CUCCX 5.0.
One of my desktop supervisors is unable to view the agent statistics and agent states in the CSD.
They have a laptop and desktop, and they can view fine from the laptop but not desktop. Any suggestions? They are using the same login for both machines.
Correct Answer by david.macias about 7 years 8 months ago
I've seen this with CAD and enterprise and most of the times it's had to do with Black Ice or a firewall installed on the PC.
david
Overall Rating: 4.5 (2 ratings)
Correct Answer
david.macias Thu, 06/11/2009 - 06:15
david
hauchinango Thu, 06/11/2009 - 06:28
David, you are correct! I disabled windows firewall and all is fine.
Any one know what ports the supervisor uses so that I can create an exception in the firewall?
