Multiple VPN connection - URGENT Help
patel.nishit
We have a ASA in the company but multiple remote users. The problem is only one user can connect to VPN at a time.
There are about 15 Users who want to connect to VPN but they are not been able to.
How do I get this working.
6 Replies 6
mvsheik123
Level 7
Level 7
Do you have any restrictions on 'vpn-simultaneous-logins' option under remote access user group policy..?
It would be easier if you post the configs, but this may be one reason.
hth
MS
Hello
Here is the config.
I have attached to this reply.
The config looks fine (unless I miss something which Gurus in the forum may be able to catch). Try to add 'isakmp nat-travesal 20'. Also, what kind of message the client receiving and any logs/debugs from ASA..?
MS
Still didn't resolve the issue.
They are getting VPN error: 443
Any log messages from ASA..?
MS
