Outpulse DTMF digits
Jun 11th, 2009
I'm trying to configure a speed dial to dial a number and then outpulse dtmf digits once the call is connected.
Does anyone know if there is a way to either insert pauses into a speed dial or allow a user to press a second speed dial after the call is connected?
Any help would be greatly appreciated.
Glenn
Jaime Valencia Thu, 06/11/2009 - 06:49
  • Cisco Employee,
  • Hall of Fame,
    2011
No option for either of that
CUCM has no means to insert pauses and speed dials cannot be used once a call is connected.
Only unity or H323 GWs using the comma (,) can insert a 1 second pause.
java
if this helps, please rate
Paolo Bevilacqua Sun, 04/28/2013 - 11:58
  • Hall of Fame,
    Founding Member
Read Release Notes of 7.5.1a firmware, page 4. It may or may not apply to your case.
Will not apply, because these apply only to SPA phones, that are not support by CM or CME.
Paolo Bevilacqua Sun, 04/28/2013 - 11:39
  • Hall of Fame,
    Founding Member
You can use my script "speed-dial with pauses" for this purpose. It can be acquired on the website mentioned in my profile.
