Crypto Map - Address Matching question
Jun 11th, 2009
Hi, I have three policies (see below)which make up a crypto map policy on a security device.
How does policy 10 match traffic if there is no "match address" statement? This is the peer I wish to edit but don't know how it is matching? Is there a default addressing match assumed?
crypto map MYCRYPTO_MAP 10 set peer 100.200.300.1
crypto map MYCRYPTO_MAP 10 set transform-set MY_TS_SET
crypto map MYCRYPTO_MAP 20 match address POLICY_ACL1
crypto map MYCRYPTO_MAP 20 set peer 100.200.300.50
crypto map MYCRYPTO_MAP 20 set transform-set MY_TS_SET
crypto map MYCRYPTO_MAP 30 match address POLICY_ACL2
crypto map MYCRYPTO_MAP 30 set peer 100.200.300.100
crypto map MYCRYPTO_MAP 30 set transform-set MY_TS_SET2
Many thanks,
srikantganesh Thu, 06/11/2009 - 06:53
A match address will be needed to specify interesting traffic.
Check if the VPN is even up.
Show crypto isakmp sa
Is it possible to test the VPN if it is not up?
srikantganesh Thu, 06/11/2009 - 07:14
under tunnel group for this vpn or the group policy is there any specific acl settings.
Can you post the tunnel group, group policy and crypto config for this vpn?
crazyhorse29 Thu, 06/11/2009 - 07:23
Hi Srikant,
No ACL settings...that is why I was wondering how the traffic is being matched? Is there a default setting?
Tunnel config below.
tunnel-group 100.200.300.1 type ipsec-l2l
tunnel-group 100.200.300.1 general-attributes
no accounting-server-group
default-group-policy DfltGrpPolicy
tunnel-group 100.200.300.1 ipsec-attributes
pre-shared-key *
peer-id-validate req
no chain
no trust-point
isakmp keepalive threshold 10 retry 2
srikantganesh Thu, 06/11/2009 - 07:24
Can you also post he output for these commands
show crypto isakmp sa
show crypto ipsec sa
crazyhorse29 Thu, 06/11/2009 - 07:29
4 IKE Peer: 100.200.300.1
Type : L2L Role : responder
Rekey : no State : MM_ACTIVE
FW# show vpn-sessiondb detail l2l filter ipaddress 100.200.300.1
Session Type: LAN-to-LAN Detailed
Connection : 100.200.300.1
Index : 1 IP Addr : 100.200.300.1
Protocol : IPSecLAN2LAN Encryption : 3DES
Hashing : SHA1
Bytes Tx : 996874716 Bytes Rx : 622313494
Login Time : 10:40:07 UTC Thu Jun 11 2009
Duration : 4h:33m:13s
Filter Name :
IKE Sessions: 1
IPSec Sessions: 2
Session ID : 1
UDP Src Port : 500 UDP Dst Port : 500
IKE Neg Mode : Main Auth Mode : preSharedKeys
Encryption : AES256 Hashing : SHA1
Rekey Int (T): 86400 Seconds Rekey Left(T): 70008 Seconds
D/H Group : 2
srikantganesh Thu, 06/11/2009 - 07:33
try show ipsec sa peer 100.200.300.1
This should include the traffic it is encrypting/decrypting for this VPN
crazyhorse29 Thu, 06/11/2009 - 07:37
Thanks Srikant,
There appears to be a local and remote subnet listed for source and desintation but I cannot find where this is defined?
This is the point of my posting as I cannot locate where it is reading this information.
Kind Regards,
srue Thu, 06/11/2009 - 06:54
how is the other side configured? as a dynamic map?
crazyhorse29 Thu, 06/11/2009 - 07:15
Thanks Steven,
The other end is checkpoint firewall with both subnets A<-->B allowed in both directions to form the tunnel.
Best Regards,
