show interfaces | include input errors
Answered Question
Jun 11th, 2009
Does anyone know if there is a IOS command which displays all interfaces on a switch which contain input errors?
Regards, Peter
Correct Answer by Leo Laohoo about 8 years 1 week ago
Hi Peter,
If you want the output which shows the interface and any line errors for the 6500 (IOS), try the command show interface counter error.
Does this help you?
Correct Answer by Collin Clark about 8 years 1 week ago
You can adjust your | command to include the interface.
sh int | i Fast|input errors
Overall Rating: 3.5 (4 ratings)
Collin Clark Thu, 06/11/2009 - 08:09
  • Purple, 4500 points or more
Your subject line works!
SW#sh int | i input errors
pverstegen Thu, 06/11/2009 - 22:55
yes, but it doesn't show the interface numbers. What I actualy need is a method to show all interfaces in a specific vlan containing input errors in a campus network of about 40 Cat.6500 switches.
I can use Kiwi Cat tools for it, but I need an effective IOS command to check for. Regards, Peter
Correct Answer
Collin Clark Fri, 06/12/2009 - 05:20
Leo Laohoo Thu, 06/11/2009 - 15:36
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Hi Peter,
You can also use the command "sh controllers ethernet-controller ".
Hope this helps.
Correct Answer
Leo Laohoo Fri, 06/12/2009 - 18:30
  • Hall of Fame,
    2017 LAN, Wireless
Hi Peter,
Does this help you?
Leo Laohoo Sun, 06/14/2009 - 14:49
  • Hall of Fame,
    2017 LAN, Wireless
Thanks for the ratings, Peter.
