Restricting Management to HTTPS Connections on the WRVS4400N
Jun 11th, 2009
Where in the web management console is the toggle to restrict management sessions to HTTPS on the WRVS4400N?
I have found this option on the WRT54G under Mangement 'Server Access' but I can not locate the setting on the WRVS4400N. I assume it must be present as it seems quite silly to drop that security setting an a more complex device with an IDS etc. built in.
Steven DiStefano Thu, 06/11/2009 - 07:44
  • Blue, 1500 points or more
FIREWALL: GENERAL
There are several radio buttons there.  Dont forget to enable remote management there as well as HTTPS
realityhack Thu, 06/11/2009 - 11:29
HTTPS is enabled in that location and Remote Management is Disabled because I do not want anyone to be able to manage the unit remotely.
I want to forbid ANY management (including local) though HTTP. This is a network security requirement.
