How to change Extension Mobility PIN and password from the Phone
Answered Question
Hi all,
How could we change Extension Mobility PIN number and Passwords from the phone? Is there any config on CCm to do?
Correct Answer by Jaime Valencia about 8 years 2 weeks ago
You can't do it from the phone, you would need to create a whole custom script to do that. You can do it from CCMUser or CCMadmin which are the ways we provide
java
if this helps, please rate
Overall Rating: 5 (1 ratings)
Correct Answer
Jaime Valencia Thu, 06/11/2009 - 07:48
  • Cisco Employee,
  • Hall of Fame,
    2011
java
