CUCM 6.1 DHCP Lease Usage
Answered Question
Jun 11th, 2009
After configured the DHCP server and DHCP subnet on CUCM, how do you monitor the lease usage by the end devices?
Correct Answer by Jaime Valencia about 7 years 10 months ago
Just the other day someone posted this
How to check DHCP leases status on cisco CCM 6x
http://pushkarbhatkoti.wordpress.com/category/ccm-5x-6x-7x-stuffs/how-to-check-dhcp-lease-on-ccm6x/
Please search previous posts using the Search NetPro function to make sure no one has asked the same thing and the answer is already there
java
if this helps, please rate
Overall Rating: 5 (1 ratings)
Correct Answer
Jaime Valencia Thu, 06/11/2009 - 07:50
  • Cisco Employee,
  • Hall of Fame,
    2011
java
