UCM 6.0
Answered Question
Jun 11th, 2009
I need to add a NTP source to UCM 6.0. I have 1 pub and 2 subs in the cluster. I currently have the pub pointing to itself for NTP source & the subs are pointing to the pub. I need to sync UCM with our LAN NTP source so the PC's & IP Phones have the same time. Do I need to create a new Phone NTP Reference and point that to the date/time group? Or should I just change the NTP source at the OS administration level? Please advise. Thanks! Jaime
Correct Answer by htluo about 7 years 7 months ago
You just need to change the NTP source at the OS administration level.
Phones will get the time from CUCM server they registered with.
Phone NTP reference is *only* used if you want to point the CUCM and the phones to different NTP sources.
Michael
http://htluo.blogspot.com
Overall Rating: 5 (1 ratings)
Correct Answer
htluo Thu, 06/11/2009 - 08:45
Michael
