VPN Tunnel problem | outside interface has private IP
Jun 11th, 2009
Hi all,
I don't know if this is a wired case or not!
When our ISP provide us with an Internet connection our Real IP is configured on the Ethernet interface, while the serial interfaces have a private IP address.
The problem here comes when i'm trying to configure a VPN tunnel to another Router.
Every thing in the configuration is smooth except the part where i set that the Serial interface is my outside.
The tunnel is always down coz the IP address will be my Private (serial interface) while the configuration on the peer router is my public IP.
So i'm wondering is there a way that i can force the VPN tunnel to take the IP configured on the LAN side? Or any other work around?
Building configuration...
Current configuration : 2372 bytes
version 12.4
boot-start-marker
boot system flash c1841-advsecurityk9-mz.124-23.bin
boot-end-marker
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp policy 2
encr 3des
hash md5
group 2
crypto isakmp key ************ address 144.254.x.y
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto map SDM_CMAP_1 1 ipsec-isakmp
description Tunnel to144.254.x.y
set peer 144.254.x.y
set transform-set ESP-3DES-SHA
match address VPN_Traffic
interface FastEthernet0/0
ip address 10.55.218.1 255.255.255.0 secondary (My Internal Subnet)
ip address 196.219.a.b 255.255.255.224 (My Public IP)
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
no keepalive
interface FastEthernet0/1
no ip address
duplex auto
speed auto
interface Serial0/0/0
no ip address
encapsulation frame-relay IETF
frame-relay lmi-type q933a
interface Serial0/0/0.16 point-to-point
ip address 172.16.133.2 255.255.255.252
ip nat outside
snmp trap link-status
frame-relay interface-dlci 16
interface Serial0/0/1
no ip address
ignore dcd
interface Serial0/0/1.16 point-to-point
ip address 172.16.134.2 255.255.255.252
ip nat outside
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Serial0/0/1.16
ip route 0.0.0.0 0.0.0.0 Serial0/0/0.16
ip access-list extended VPN_Traffic
remark Protect traffic from Local subnet to any Destination
remark SDM_ACL Category=4
permit ip 10.55.218.0 0.0.0.255 any
scheduler allocate 20000 1000
end
mlitka Thu, 06/11/2009 - 09:40
Does this router have a static NAT statement on the upstream device?
