Packet drop in L2L VPN tunnel
Jun 11th, 2009
MY ASA5540 has 40 L2L IPsec VPN tunnels to other sites. One of tunnels has packet drop often ( but the tunnel remind up ). Called ISP and confirm its not ISP issue. Is there any method to troubleshoot the issue ? what should I look at in the configuration ? any help will be appericated.
thotsaphon Thu, 06/18/2009 - 10:39
Kwok Hung Ken Wu,
I'm not sure that they are sending traffic by using udp/4500 or not. In case of ESP when link flapping occurred you may find something about invalid SPI.That would be a problem because the database has not been synchronized. If you're facing this please add a "crypto isakmp invalid-spi-recovery" command for testing.
HTH,
Toshi
