Failure Archiving Device Configs...
Jun 11th, 2009
Hi Everyone, I am having issues archiving configs for some of my devices. I am using Ciscoworks 3.1 and RME 4.2.0
I am getting the following error:
"Could not detect SSH protocols running on the device TELNET: Failed to establish TELNET connection to (Device IP) - Cause: Connection refused."
I can connect with SSH to the device using the credentials I have in Ciscoworks.
Does anyone know what could be causing this?
Joe Clarke Thu, 06/11/2009 - 10:14
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
What type of device is this? What version of code is it running?
alejreyes Thu, 06/11/2009 - 10:27
We have 3750-24P running c3750-ipservicesk9-mz.122-46.SE, a 2851 router running c2800nm-ipbasek9-mz.124-15.T7.bin, and a 3750-24P running c3750-ipservicesk9-mz.122-35.SE5. We also have other devices with the same version of code and those are working great.
Joe Clarke Thu, 06/11/2009 - 10:33
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Telnet to port 22 of these devices. What output do you get?
alejreyes Thu, 06/11/2009 - 10:43
Hi Clarke, I am getting the following output. We have telnet disabled and have SSH enabled on the devices.
SSH-2.99-Cisco-1.25
Joe Clarke Thu, 06/11/2009 - 10:46
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
That's what I thought. This is a known device bug, CSCsq51052. As a workaround, you will need to disable SSHv2 (i.e. no ip ssh version 2).
alejreyes Thu, 06/11/2009 - 11:11
Hi Clarke, I disabled SSHv2, then enabled it again. I am now able to archive their configs successfully. Thanks for all your help.
