Leaking VRF loopback address to gobal routing table
Reza Sharifi
I have a router and have configured multiple VRFs. I was also able to leak routes between the global routing table and one of the VRFs (VRF data) successfully.
Now, I have not been able to leak the loopback address of the VRF data (1.1.1.1) into the global routing table, so I can ping the VRF loopback address from the global routing table.
I have also read this article:
http://www.cisco.com/en/US/tech/tk436/tk832/technologies_configuration_example09186a0080231a3e.shtml
Has any one experienced this before?
Attached is the config
Reza
If VRF select is not supported, you can create a fake route-map and apply it to the loopback interface:
route-map FAKE
set vrf data
int loopback 0
ip policy route-map FAKE
ip vrf receive data
http://www.cisco.com/en/US/docs/ios/mpls/configuration/guide/mp_vpn_vrf_select_rt_ps6441_TSD_Products_Configuration_Guide_Chapter.html
Laurent.
Laurent Aubert
Hi Reza,
If you want the loopback to be seen from the VRF and the GRT, you can use the following command instead of the ip vrf forwarding:
int loopback 1
ip vrf select source
ip vrf receive data
Laurent.
Hi Laurent,
Thanks for the reply.
One of the commands (ip vrf select source) is not available (maybe I do not have the right IOS)and for the other command it asks me to enable policy routing first.
Here is the output:
Also, I am running
System image file is "flash:/c2800nm-adventerprisek9_ivs-mz.124-3g.bin"
T-1(config-if)#do sh run in lo1
Building configuration...
Current configuration : 63 bytes
interface Loopback1
ip address 1.1.1.1 255.255.255.255
end
T-1(config-if)#ip vrf receive data
% Need to enable Policy Based Routing on the interface first
T-1(config-if)#ip vrf ?
forwarding Configure forwarding table
receive Add Interface Address into VRF Table
sitemap Configure route-map for routes received from this site
ip vrf
ip vrf
% Incomplete command.
T-1(config-if)#
route-map FAKE
set vrf data
int loopback 0
ip vrf receive data
Laurent.
Laurent,
I just tested this
It works very well
Thanks for your help
Reza
