Cyberdata VOIP Loudspeaker Amplifier
Jun 11th, 2009
UCM 7.1
I have gotten this to register and work but what I am running into is the ability for this device to stay registered. I looked at the manufactures website that talks about this same issue but I am not sure what timer in the Service parameters that this is exactly referring to. Link makes mention of a re-registration time value but not sure what exactly of this parameter.
http://www.cyberdata.net/products/voip/digitalanalog/loudspkramp/index.html#Q19
Nicholas Matthews Thu, 06/11/2009 - 10:19
Can you be more specific about exactly how this is registering, protocols, devices, etc?
-nick
mattcalderon Thu, 06/11/2009 - 10:36
Sure,
This the guide that I used for both sides.
http://tinyurl.com/nsgxt2
Essentially though, I added a third-party SIP device (basic) and then created a user and associated the user to SIP device.
On the cyberdata side, it was just pointing the device to UCM and putting the credentials in from the user that i created.
Seems pretty simple right?? It just wont stay registered. It does work when it is registered though.
